Adding Extensions to Evok
I've a hard time to add an extension to evok, I tried different settings in the /etc/evok.conf - no success. Found also no documentation about the extensions and how to add them without using mervis.
To be more specific I use Raspbian GNU/Linux 9.1 (stretch) with a Neuron L40x and a xS30 Extension.
/etc/evok.conf:
;[EXTENSION_1] device_name = xS30 modbus_uart_port = /dev/extcomm/0/0 allow_register_access = False scan_frequency = 2 scan_enabled = TrueDIP switches on the extension are all OFF, cable length 30cm
Hi
use[EXTENSION_1] global_id = 2 device_name = xS30 modbus_uart_port = /dev/extcomm/0/0 neuron_uart_circuit = 1_01 allow_register_access = True address = 15 scan_frequency = 2 scan_enabled = True baud_rate = 19200 parity = N stop_bits = 1Regards
Thanks, worked out for me
