    UniPi1.1 and I2C voltage levels
    Unipi 1 - First Generation
    • G
      Giancarlo Bazzi last edited by
      Hi, I'd like to drive an LCD characters display that uses I2C bus with 5V DC levels for SDA and SCL.
      What voltage range is supported by the I2C connection of the UniPi1.1?
      Is it 3.3V as per the Raspberry Sor is there a voltage level shifter to get/accept 5V DC on I2C pins?
        mglowinski last edited by
        @Giancarlo-Bazzi did you manage to set 3.3V as I2C voltage level?
