    Problem using cmd:all using Websockets
    • O
      oflock last edited by
      Dear all,
      I try to use the cmd:all command using Websocket to retrieve all values at connexion in my custom UI.
      After digging into the source code, I managed to understand that there is a problem in the current master code on the Github:
      In evok.py, the line 113:
      result += map(lambda dev: dev.full(), Devices.by_int(dev))
      returns this exception when cmd:all command is fired:
      Exc: unsupported operand type(s) for +=: 'dict' and 'list'
      Could you please help me to correct this, as I really need this functionnality ? I would like not to have to use the REST API to do that, as I do everything using Websockets.
      Best regards.
      Olivier.
        TomasKnot last edited by
        Hi Olivier,
        The issue should now be fixed in the latest commit. Please see if it works for you, thank you for reporting the bug.
        Kind regards,
        Tom
        • O
          Hi Tom,
          great ! Problem fixed !
          Thanks for your fast answer and support.
          Regards.
          Olivier.
