    Z-wave module
    Other Peripherals
    • W
      wszadkow last edited by
      Hi
      Is there a possibility of communication UniPi Neuron with Z-Wave?
      I found this adapter auction:
      http://www.ebay.pl/itm/Z-Wave-Me-UZB-USB-Stick-ZME-UZB1-Z-Wave-Plus-Smart-Home-US-Version-/371306991069
      but I do not know how to configure it ...
      Can someone help me?
        abornand last edited by
        Is there any way to bind a z wave modules to Evok or Mervis ?
        Regards
          tomas_hora administrators @abornand last edited by
          @abornand
          There is no support for Zwave in Mervis or Evok right now, however other SW platforms could be compatible depending on your needs
          A 1 Reply Last reply Reply Quote 0
            abornand @tomas_hora last edited by
            @tomas_hora
            Hello Thanks for your answer. Which software you will suggest to use that is compatible with Mervis or Evok ?
            Regards
            T B 2 Replies Last reply Reply Quote 0
              tomas_hora administrators @abornand last edited by TomasKnot
              @abornand Definitely cross out Mervis - it's not meant and designed for such things.
              Regarding the othwer SW for Zwave, some uses Evok API to acces the IOS, some that dont might not be compatible with Neuron - check https://www.unipi.technology/products/other-software-overview-59?categoryId=6&categorySlug=software
              • B
                BlackSoll @abornand last edited by
                @abornand
                Hi ! I use aeotec z-stick with unipi and pimatic. The pimatic plugin works with neuron too. No problems so far. I control around 11 devices. Althought pimatic is at beta stage, works now for my home automation over a year.
