RUN1 & RUN2 blinking in 2-second interval
I bought Neuron M403, it's running Minibian and I'm having trouble getting it to work (e.g. accessing both groups, switching on/off relays).
- I have successfully installed Evok directly from master
- Evok service is running
- neuron_tcp_server is running
root 276 0.0 0.1 2384 1552 ? Ss 10:18 0:00 /opt/neurontcp/neuron_tcp_server -p 502 --check-firmware root 277 1.1 1.5 19812 15388 ? Ss 10:18 0:01 /usr/bin/python /opt/evok/evok.py --path1=/etc/evok.conf --path2=/etc/evok-neuron.conf message+ 280 0.0 0.2 5408 2796 ? Ss 10:18 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation root 287 0.0 0.0 1608 316 ? Ss 10:18 0:00 runsv git-daemon gitlog 289 0.0 0.0 1752 968 ? S 10:18 0:00 svlogd -tt /var/log/git-daemon gitdaem+ 293 0.0 0.1 3608 1724 ? S 10:18 0:00 /usr/lib/git-core/git-daemon --verbose --reuseaddr --base-path=/var/lib /var/lib/git root 302 0.0 0.2 3768 2416 ? Ss 10:18 0:00 /lib/systemd/systemd-logind root 329 0.0 0.1 3964 1708 tty1 Ss+ 10:18 0:00 /sbin/agetty --noclear tty1 linux root 330 0.0 0.1 3784 1896 ttyS0 Ss+ 10:18 0:00 /sbin/agetty --keep-baud 115200 38400 9600 ttyS0 vt102 nobody 344 0.0 0.1 2204 1436 ? Ss 10:18 0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/thd.pid --user nobody /dev/input/event* ntp 353 0.0 0.3 5328 3628 ? Ss 10:18 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -c /var/lib/ntp/ntp.conf.dhcp -u 105:109 root 391 0.0 0.3 7140 3736 ? Ss 10:18 0:00 /usr/sbin/apache2 -k start www-data 394 0.0 0.3 229548 3412 ? Sl 10:18 0:00 /usr/sbin/apache2 -k start www-data 395 0.0 0.3 229548 3412 ? Sl 10:18 0:00 /usr/sbin/apache2 -k start root 450 0.0 1.2 19488 12136 ? S 10:18 0:00 /usr/bin/python /opt/evok/evok.py --path1=/etc/evok.conf --path2=/etc/evok-neuron.confWhen I run the Neuron TCP server manually...
$ /opt/neurontcp/neuron_tcp_server -p 502 --check-firmware --verbose Board on /dev/spidev0.1 firmware=4.6 hardware=0.16 (B-1000-1) Cannot open device: No such file or directory Cannot open device: No such file or directory Board0 PTY0 /dev/pts/2 Starting loopWhen I run Evok manually...
$ ./evok.py eprom:: UniPi Neuron M403 version: 1.0 serial: 0x8 Using config file /etc/evok-neuron.conf HTTP server listening on port: 8088 Entering 1wire loop New WebSocket client connected [I 170125 09:51:24 web:1971] 200 GET /rest/all (192.168.7.185) 2.81msContents of
/etc/evok-neuron.conf...#!! don't use # for inline comments [MAIN] webname = unipi-neuron staticfiles = /var/www/evok ;password = test ;rpcpassword = test secret = ut5kB3hhf6VmZCujXGQ5ZHb1EAfiXHcy port = 80 enable_cors = False cors_domains = * modbus_port = 0 #modbus_address = 127.0.0.1 modbus_address = * [NEURON_1] scan_frequency = 2 [OWBUS_1] owbus = --i2c=/dev/i2c-1:ALL ; scanned bus (--i2c=/dev/i2c-1:ALL or localhost:2122 or 'u' for USB dongle) interval = 3 ; [s] default sensor reading scan_interval = 300 ; [s] how often is made searchingWhen I send a GET request to
/rest/all(Evok REST API), this is what I get...[ { "circuit": "1_01", "debounce": 50, "counter": 0, "value": 0, "dev": "input", "counter_mode": "disabled" }, { "circuit": "1_02", "debounce": 50, "counter": 0, "value": 0, "dev": "input", "counter_mode": "disabled" }, { "circuit": "1_03", "debounce": 50, "counter": 0, "value": 0, "dev": "input", "counter_mode": "disabled" }, { "circuit": "1_04", "debounce": 50, "counter": 0, "value": 0, "dev": "input", "counter_mode": "disabled" }, { "value": 0, "pending": false, "circuit": "1_01", "dev": "relay" }, { "value": 0, "pending": false, "circuit": "1_02", "dev": "relay" }, { "value": 0, "pending": false, "circuit": "1_03", "dev": "relay" }, { "value": 0, "pending": false, "circuit": "1_04", "dev": "relay" }, { "value": 0.0159, "circuit": "1_01", "dev": "ai" }, { "value": 0.014369322022101755, "circuit": "1_02", "dev": "ai" }, { "value": 0.0105, "circuit": "1_01", "dev": "ao" } ]The group 2 is completely missing.
When I try to switch a relay from the second group (
POST /rest/relay/2_01), I'm getting an error{"errors": {"__all__": "Invalid device circuit number 2_01"}, "success": false}.What am I doing wrong? Could you please help me?
@Baggz It seems that the SPI overlay is not enabled. Please try to reinstall the tcp modbus server including the overlay and paste the output please
https://github.com/UniPiTechnology/neuron_tcp_modbus_overlay
You should see also devices SPIDEV0.1 and SPIDEV0.2 in /dev/
@tomas_hora, thanks for the reply!
Here's the output when installing the Overlay again.
$ git clone https://github.com/UniPiTechnology/neuron_tcp_modbus_overlay.git Cloning into 'neuron_tcp_modbus_overlay'... remote: Counting objects: 32, done. remote: Total 32 (delta 0), reused 0 (delta 0), pack-reused 32 Unpacking objects: 100% (32/32), done. Checking connectivity... done. $ cd neuron_tcp_modbus_overlay/ $ ls LICENSE README.md install.sh neuron_tcp_server spi_overlay $ chmod +x install.sh $ ./install.sh Installing libmodbus Hit http://archive.raspberrypi.org jessie InRelease Hit http://archive.raspberrypi.org jessie/main armhf Packages Ign http://archive.raspberrypi.org jessie/main Translation-en Hit http://mirrordirector.raspbian.org jessie InRelease Hit http://mirrordirector.raspbian.org jessie/main armhf Packages Hit http://mirrordirector.raspbian.org jessie/firmware armhf Packages Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages Ign http://mirrordirector.raspbian.org jessie/firmware Translation-en Ign http://mirrordirector.raspbian.org jessie/main Translation-en Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en Reading package lists... Done Reading package lists... Done Building dependency tree Reading state information... Done libmodbus-dev is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. Enabling SPI overlay Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /fragment@1 has a unit name, but no reg property mkdir: cannot create directory '/opt/neurontcp': File exists Compiling neurontcp server... gcc -g -c -I . armspi.c -o armspi.o gcc -g -c -I . spicrc.c -o spicrc.o gcc -g -c -I . nb_modbus.c -o nb_modbus.o gcc -g -c -I . armpty.c -o armpty.o gcc -g -c -I . neuron_tcp_server.c -o neuron_tcp_server.o gcc -g neuron_tcp_server.o armspi.o spicrc.o nb_modbus.o armpty.o -lmodbus -lutil -o neuron_tcp_server gcc -g -c -I . neuronspi.c -o neuronspi.o gcc -g neuronspi.o armspi.o spicrc.o -o neuronspi gcc -g -c -I . bandwidth-client.c -o bandwidth-client.o gcc -g bandwidth-client.o armspi.o spicrc.o nb_modbus.o armpty.o -lmodbus -lutil -o bandwidth-client Installing Neuron TCP server into /opt/neurontcp/ cp: cannot create regular file '/opt/neurontcp/neuron_tcp_server': Text file busy Enabling neurontcp service for systemd Reboot is required. Is it OK to reboot now? [y/n] yWhen I try to compile just the SPI Overlay, this what I get.
$ sh compile-dtc Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /fragment@1 has a unit name, but no reg propertyAlso, contents of the
/boot/config.txtis...gpu_mem=16 dtparam=spi=on dtparam=i2c_arm=on #Enable i2c bus 1 device_tree_param=i2c1=on #Enable UniPi Neuron SPI overlay dtoverlay=neuron-spi dtoverlay=w1-gpio enable_uart=1Isn't the issue in Minibian? Shall I try Raspbian?
@Baggz It seems OK, did you restart the OS?
Yes, I did. Still the same. :-(
@Baggz Try commenting out the dtparam=spi=on and dtoverlay=w1-gpio and reboot
Howeve I did not test it with minibian but shoudl be ok. Raspbian definitely works..
Thank a lot for your help!
I end up using Raspbian and it works out of the box! :-) Minibian seems to be a bit buggy, wouldn't recommend.
Thanks!
BTW, I absolute love Neuron! <3 I'll put it everywhere.
Having a simple REST API is a bless.
Thank you for all your hard work that goes into UniPi!
