    Analog out connection
    • zorro_66
      zorro_66 last edited by
      Have I got the guide right as shown below
      [attachment=0:1ik92v4u]Analog4.jpg[/attachment:1ik92v4u]
      • zorro_66
          Guest last edited by
          If you want to use external power supply, you do not need to make connection to the AI- and definitely not to 12V!
          Just connect the positive pole to AOV, negative to AOG.
          By the way, minimum voltage on the AOV is 12V in order to be able to get 10V on the AO.
          • zorro_66
            Ok I connect like this when I should use power from Unipi
            [attachment=1:1kdnxhhn]Analog1.jpg[/attachment:1kdnxhhn]
            and I connect like this when I use an external power supply
            [attachment=0:1kdnxhhn]Analog11.jpg[/attachment:1kdnxhhn]
              Right
              • zorro_66
                ok tanks
