    Siemens SQX62
    • zorro_66
      zorro_66 last edited by
      I would like to use my actuators for underfloor heating with unipi
      Is it possible to connect 24 Vac on analog on unipi as illustrated.
      Then replace N1 with a unipi
      [attachment=1:3p3de0wg]Siemens SQX62.jpg[/attachment:3p3de0wg]
      Connection as shown below
      SN>A0G
      SP>A0V
      Y>A0
      [attachment=0:3p3de0wg]Analog_unipi.jpg[/attachment:3p3de0wg]
      • zorro_66
        SN>A0G
        SP>A0V
        Y>A0
          Guest last edited by
          You definitely do not want to connect 24V AC
          But what is a little confusing that the connector has 0-10V DC but does not have a proper GND for it... Or am I missing anything? Because you cannot connect the GND of UniPi to the AC gnd. But if you find where to put gnd for the 0-10V than you can easily connect it according to the second picture
          • zorro_66
            GND to 0-10V DC sits on G0 24VAC on Siemens RLE162 regulator
            • zorro_66
              The problem is solved
