    Button to light
    • SorakCz
      SorakCz last edited by
      I try to create button to light. Button is connected to digital input. I need this action:
      first click switch on
      secont click switch off
      In next steps i want to try doubleclick.
      Is in Mervis some element for this simulation?
      I Tried it in Fupla with AND, OR and negation elements, but it did not work correctly.
      Thank
      • SorakCz
        Thank
          Guest last edited by
          first of all you might need to set the sleep mode to minimum because the runtime run in loops which takes some time (not event-driven system) so it is highly possible you will not be able to catch pulses that do not take much time.
          I recommend making your own function block in st (see the video tutorials https://www.youtube.com/playlist?list=P ... ugVSn2K1RL )
