    Issues finding the correct block
    axon
    1
    • Bart Delaere
      Bart Delaere last edited by
      In my mervis program I have an Analog output A201 that I want to trigger by 1 DI (button). short push is ON/OFF. Long push is to dim the light UP/DOWN.
      The documentation is advising to use the AOI block, but the documentation is not clear to me.
      Input:
      mode 0 -> is 0-10V
      target_value REAL -> what is needed here?
      Vref_1 INT -> what is needed here?
      VrefInt_1 INT -> what is needed here?
      A0_A_DEV_1 INT
      AO_A_Offset_1
      A0_V_DEV_1 INT
      AO_V_Offset_1 INT
      AIO_1 INT
      AIO_V_Offset_1 INT
      measuring current INT
      These I do not understand, it speeks of ... needs to be connected to the ... of the device. But I only have the Analog input of the dimmer (0-10V), can somebody give me some information about this function block please
      Output:
      AO_1 -> AO_202
      Can somebody give me some clear information about this functionblock, or do I need an other block?
      I have other brands that are simple and cleare, here I have no clue what to do. Please clear this out for me.
      • Bart Delaere
        Maybe somebody can help me out with a dimmer function. I want to use a push button and use a AO as output.
        When I puls it should go on/off, and when you push long, It should dim more/less.
        I can't figger it out. I am wondering through the documentation and can't find the right block(s)
        What block(s) should I use ?
        Anybody any ideas?
        • Bart Delaere
          Is nobody using the Analog output (0-10V) to dim LED lights?
