    Wireless AP / UnipiAP function
    2 Posts 2 Posters 1.6k Views
      domguard
      Having the Unipi as an access point would simplify my last project
      When using installed image or apt with EVOK, the systemd services seems not to be installed.
      So I tried the 2.4.30 legacy script install, changing the NO_WIFI=true parameter to false, it sort of worked, I had to install hostapd by myself but ended with an hostapd error : Failed to start Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
      The SSID was visible but I could not connect to it.
      Is there a way to easily use this Evok/Unipi feature ot let's say it's dead ?
      thank you very much
        AVsetula
        Hi @domguard,
        The mentioned problems should not be related to EVOK at all. It's not clear from your description what kind of controller you have or what you actually need. Do you need to connect to an existing WiFi, or do you want to create a WiFi access point from the controller?
        But EVOK works normally, right?
        Antonin, Unipi team
