    Neuron Older Models M20x
    1 Posts 1 Posters 1.1k Views
      Merv
      Hi, I have a M20x that I want to replace with a new device, is the M203 a direct swap, just a newer model number? I use a custom Python program that reads and sets using requests. Some of my procedures:
      def read_button(button):
          try:
              Status = urllib.request.urlopen("http://" + myself + "/rest/di/" + button).read()
              jsondata = json.loads(Status.decode("utf-8"))
              x = jsondata["value"]
          except Exception as e:
              # print('Read button fail, no button called',button)
              x = True
          return x
      def set_relay(circuit, onoff):
          data = dict(value=onoff)
          url = "http://" + myself + "/rest/relay/" + circuit + "/"
          content = requests.post(url, data=data, allow_redirects=True)
      Should I expect that all the relays, di, do, ai, ao access will be the same? I guess what I'm asking is, should I expect that my program will run the same on the M203 as it did on the M20x?
      And separately, if I changed to the Patron devices, would the evok system be accessable in the same way as I've accessed it with my python code? Would it be an easy change over?
      Thanks!
      Merv
