S103 rs485 modbus sensor
I have a UniPi Neuron S103 (latest OpenSource OS available) and I want to connect it, via RS485 MODBUS RTU, to a SenseCAP ORCH S4 sensor.The connection details for the ORCH S4 are specified here:
- baudrate 9600
- address 14
- no parity
- stop bit 1
- start bit 1
- bit count 8
On the s103 I've installed evok and it's working fine, but I don't get any values from the sensor. The connection between the s103 and the sensor is working because I was able to read the values via mbpoll
# mbpoll /dev/extcomm/0/0 -m rtu -a 14 -b 9600 -c 8 -P none Protocol configuration: Modbus RTU Slave configuration...: address = [14] start reference = 1, count = 8 Communication.........: /dev/extcomm/0/0, 9600-8N1 t/o 1.00 s, poll rate 1000 ms Data type.............: 16-bit register, output (holding) register table -- Polling slave 14... Ctrl-C to stop) [1]: 1629 [2]: 6752 [3]: 1 [4]: 34408 (-31128) [5]: 151 [6]: 8299 [7]: 4 [8]: 2575What am I doing wrong? I'm guessing it's something related to the modbus registry definitions, but I don't know how to fix it. Can someone point me in the right direction? thanks
Here's my /etc/evok.conf
[MAIN] ; !!! ALL MAIN SECTION OPTIONS ARE MANDATORY !!! config_version = 2.5 ; Configuration file version, DO NOT CHANGE! use_schema_verification = False ; Enabling this will deny any requests that do not match the JSON Schema; NOTE THAT THIS RESULTS IN A SIGNIFICANT INCREASE IN LATENCY AND SHOULD NOT BE USED EXCEPT FOR TESTING log_level = ERROR ; Minimum severity of messages to be logged; one of INFO, DEBUG, WARNING, ERROR, CRITICAL log_file = /var/log/evok.log ; Log file to use; will be cleared on boot port = 8080 ; !!! Internal API port - only change if you are certain you know what you are doing; FOR OUR WEB INTERFACE THE PORT SHOULD BE CHANGED IN "/etc/evok-nginx.conf" INSTEAD !!! webhook_enabled = False ; Enables webhook notification - see e.g. https://sendgrid.com/blog/whats-webhook/ webhook_address = http://127.0.0.1:80 ; Put your server endpoint address here (e.g. http://123.123.123.123:/wh ) webhook_device_mask = ["input","wd"] ; List of device types to notify on (written as a JSON list) - adding AI will generate a large amount of messages! webhook_complex_events = False ; EVOK will send POST requests with the same data as WebSocket, rather than an empty GET request soap_server_enabled = False ; Enables the simple SOAP server; use only if you need the functionality soap_server_port = 8081 ; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. different from the port setting above) !!! force_immediate_state_changes = False ; Outputs will return the value they are set to, rather than the value that the device is currently aware of websocket_all_filtered = False ; 'All' WebSocket requests will be subject to the filtering set by 'filter' [NEURON_1] global_id = 1 ; Mandatory, REQUIRED TO BE UNIQUE allow_register_access = False ; Optional, False default scan_frequency = 10 ; Optional, 10 default, scanning frequency in [Hz] scan_enabled = True ; Optional, True default [EXTENSION_2] global_id = 3 device_name = ORCHS4 modbus_uart_port = /dev/extcomm/0/0 allow_register_access = True address = 14 parity = N baud_rate = 9600 stop_bits = 1and my /etc/hw_definitions/ORCHS4.yaml
type: ORCHS4 modbus_register_blocks: - board_index : 1 start_reg : 0 count : 8 frequency : 50 modbus_features: - type : REGISTER major_group : 1 count : 1 start_reg : 0 - type : REGISTER major_group : 1 count : 2 start_reg : 1and here's the logs from evok execution
# /opt/evok/bin/python /opt/evok/lib/python2.7/site-packages/evok/evok.py [I 221013 08:40:56 config:78] eprom: UniPi Neuron S103 version: 2.4 serial: 0xec [I 221013 08:40:56 evok:1899] Starting using config file /etc/evok.conf [I 221013 08:40:56 config:103] YAML Definition loaded: xS11.yaml, type: 3, definition count 0 [I 221013 08:40:56 config:103] YAML Definition loaded: IC-Light1P-1.yaml, type: 3, definition count 1 [I 221013 08:40:56 config:103] YAML Definition loaded: ORCHS4.yaml, type: 3, definition count 2 [I 221013 08:40:56 config:103] YAML Definition loaded: xS50.yaml, type: 3, definition count 3 [I 221013 08:40:56 config:103] YAML Definition loaded: xS10.yaml, type: 3, definition count 4 [I 221013 08:40:56 config:103] YAML Definition loaded: xS51.yaml, type: 3, definition count 5 [I 221013 08:40:56 config:103] YAML Definition loaded: CUSTOM_MODBUS_DEVICE.yaml, type: 3, definition count 6 [I 221013 08:40:56 config:103] YAML Definition loaded: IC-AiUC8-2.yaml, type: 3, definition count 7 [I 221013 08:40:56 config:103] YAML Definition loaded: xS30.yaml, type: 3, definition count 8 [I 221013 08:40:56 config:103] YAML Definition loaded: IC-DiS2Do2-1.yaml, type: 3, definition count 9 [I 221013 08:40:56 config:103] YAML Definition loaded: xS40.yaml, type: 3, definition count 10 [I 221013 08:40:56 config:103] YAML Definition loaded: xG18.yaml, type: 3, definition count 11 [I 221013 08:40:56 config:110] YAML Definition loaded: /etc/hw_definitions/BuiltIn/S103.yaml, type: UniPiBuiltIn [I 221013 08:40:56 config:103] YAML Definition loaded: IAQ.yaml, type: 3, definition count 12 [I 221013 08:40:56 config:103] YAML Definition loaded: evok-alias.yaml, type: 2, definition count 0 [I 221013 08:40:56 evok:1969] HTTP server listening on port: 8080 [I 221013 08:40:56 modbusclient_tornado:134] TCP/Modbus client to 127.0.0.1:502 started [I 221013 08:40:56 modbusclient_rs485:361] UART client started [I 221013 08:40:56 neuron:325] Reading the Modbus board on Modbus address 14 [I 221013 08:40:56 neuron:215] Reading SPI boards [I 221013 08:40:56 owclient:450] Entering OWW loop with PID 2087 [I 221013 08:40:56 neuron:230] No board on SPI 2 [I 221013 08:40:56 neuron:230] No board on SPI 3
