How to use EMO-R8 directly ?
This post is deleted! -
ONLY in English ...
I have a Unipi 1.1 card and an 8 relay extension EMO-R8.
I can drive the Unipi card (I2C address 0x20).
The EMO-R8 module is configured to I2C address 0x22.But unlike the relays on the Unipi board, I can't do anything with the EMO-R8 module.
Nothing happens :(
Here is my program which works perfectly with the Unipi 1.1 board:
#!/usr/bin/python # # Testing relays # import smtplib import math import smbus import time # Open the bus bus = smbus.SMBus(1) # Force output ports bus.write_byte_data( 0x20, 0x00, 0x00 ) wait5s=5 wait=0.125 # Activates relays and switches them off for value in [0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80]: bus.write_byte_data( 0x20, 0x09, value ) time.sleep( wait5s ) # Activates relays and switches them off for value in range(0,80): bus.write_byte_data( 0x20, 0x09, value ) time.sleep( wait ) # Activates relays and switches them off for value in range(80,0, -1): bus.write_byte_data( 0x20, 0x09, value ) time.sleep( wait ) # Activates relays and switches them off for value in [0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01]: bus.write_byte_data( 0x20, 0x09, value ) time.sleep( wait ) # Force ports to zero bus.write_byte_data( 0x20, 0x09, 0x00 )See the list of I2C addresses used :
root@raspberrypi-002:/home/pi# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- -- 20: 20 -- 22 -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- 6f 70: -- -- -- -- -- -- -- --This gives in readable form :
Chip Adress Usage Board ----------------------------------------------------- DS2482-100 0x18 1Wire master Unipi 1.1 MCP23008 0x20 Relays Unipi 1.1 MCP23008 0x22 Relays EMO-R8 24AA00/24C02 0x50-0x57 EEPROM Unipi 1.1 MCP79410 0x57,0x6F Real time clock Unipi 1.1 MCP3422 0x68 ADC Unipi 1.1root@raspberrypi-002:/home/pi/unipi# i2cdetect -l i2c-1 i2c bcm2835 (i2c@7e804000) I2C adapterWhen I operate the Unipi relay ports :
I have activated the MCP23008 (on the Unipi 1.1):
It works perfectly :)
Initialisation of port 0x20 (Unipi 1.1) :
root@raspberrypi-002:/home/pi/unipi# i2cset -y 1 0x20 0x00 0x00 root@raspberrypi-002:/home/pi/unipi# i2cset -y 1 0x20 0x09 0x01 root@raspberrypi-002:/home/pi/unipi# i2cset -y 1 0x20 0x09 0x00How to use port 0x22 (EMO-R8) ?
Because the following does not work :(
Initialization of port 0x22 :
root@raspberrypi-002:/home/pi/unipi# i2cset -y 1 0x22 0x00 0x00 root@raspberrypi-002:/home/pi/unipi# i2cset -y 1 0x22 0x09 0x01 root@raspberrypi-002:/home/pi/unipi# i2cset -y 1 0x22 0x09 0x00Do I need to do anything special to make the EMO-R8 modules work ?
I know, that there are Unipi solutions via their programs. But, I want to be free and not use a program that will have difficulty interfacing with other programs specific to my needs.
That's why I prefer to access the controllers directly and do exactly what I want.
Thank you for your help :)
JB
Hello @PythonRunner ,
it seems weird. There should be no traps - just one MCP23008 in the "typical" schematic.
Do you have a power supply for the EMO board strong enough?
Have you checked the functionality even with the Unipi software (e.g. Evok)?
@martin_triska Thank you for this answer :)
As you can see the addresses of both MCP23008 are visible.
0x20 for the MCP23008 on the Unipi 1.1 board
0x22 for the MCP23008 of the EMO-R8 expansion boardAnd both boards have their own power supplies purchased from Unipi (CLW-1005-W2E-EB) of 5V in 2A.
And with or without, it doesn't matter...
So I made a new RJ11 cable and it worked :)
Life is simple especially with a good connection....
