    Websockets Disconnecting
    Node-RED
      DAWaller last edited by
      Hi All
      Wonder if anyone has any ideas, My Raspberry Pi occasionally drops the Websockets connection to the Unipi, I can't see anyway to have it reconnect apart from a reboot.
      Is there's some logs I can check to see why its dropping connection, or some way of monitoring the connection to warn me if it drops and maybe a way to cause a reconnect?
      Cheers.
      David
        Martin Kudláček @DAWaller last edited by
        Hello @DAWaller,
        please share a bit more information. What software do you use? Are you connecting to the Evok? Can you verify, whether the Evok stops responding on the websockets entirely?
          Good Evening
          I'll be honest, not 100% sure, still a bit of a beginner. I'm using the Node Red image from the unipi website. How would I check the Evok?
          Cheers
          David
            martin_triska last edited by
            Hello @DAWaller,
            can you please describe your application in more detail? Websocket connection is provided by Evok software. Node-RED uses this type of connection to communicate with the I/Os.
            Do you see the connection outages from Node-RED running on the same unit?
            What displays the Node-RED debug console?
