    Radiator valve heads
    Other Peripherals
    1
    • P
      Pavelf last edited by
      Assuming house with water radiators in each room and water heated centrally.
      How is individual room control done with unipi?
      I understand there would be a temp. Sensor in each room but how / what opens flow to the radiator?
      2nd q:
      Is the system compatible with solutions from eq-3such as Max! Or Homematic?…assuming control of these systems to be done via FHEM
      Pavel
      • P
        2nd q:
        Pavel
          Guest last edited by
          The vedt solution is to have a 220V radiator valves connected to relay of unipi. He have done this with fhem and works well.
          Or as you ask in your second question you can use fhem with unipi and max/homematic gateway and one of their valve controllers - also possible.
