    Analog output Hardware problem
    Unipi 1 - First Generation
    • F
      FabioIT last edited by
      Hello
      I read the guide https://kb.unipi.technology/en:automation:02-glossary:analog-outputs-hidden
      to use my AO in my Unipi1.1
      I'm sure i'm setting the output (AO01) by the onboard 12 V as described on tutorial and I can read on AI 1,0000 V in all range of 0-100% of the AO output by software.
      Also if I try to trimmer the voltage it has't any effect.
      If I detach the wire AOG AI1+ I can read 10,000V on AI1 .. what means?
      Thank you for your support
        Martin Kudláček @FabioIT last edited by
        Hello @FabioIT,
        can you please share the wiring diagram and the jumper settings?
        Thanks,
