    Only 2 1-wire sensors are detectable
      ArneL last edited by ArneL
      Hello, I have one L203 with RJ 45 1-wire port.
      I attached a 8-port hub to it and connected 5 sensors in sequence (2-6)
      In the evok but also in Mervis before, I could only see and find 2 sensors. I changed the positions of the sensors (put sensor 4 and 5 to port 2 and 3 and so on) and could read the data of the sensors 4 and 5 only which means that all of them are correctly wired.
      I have two hubs, the error occured with both!
      How can I fix this issue?
      Thanks,
      Arne
        Martin Kudláček administrators @ArneL last edited by
        Hello @ArneL,
        what sensors do you use?
        Thanks,
