    1W-TH-IB2 communication error detection
    Scheduled Pinned Locked Moved Other Peripherals
    2 Posts 2 Posters 1.2k Views
      Jan Toth
      is there any way how to control communication error or failure on 1-wire sensor 1W-TH-IB2? I can not find similar variables like at 1-wire temperature sensor - Scratchpad_commerror. In case of error sensor holds last value. What is the best practise how to protect against communication errors?
      Thanks for reply.
      Jan Toth
        martin_triska
        Hello @Jan-Toth,
        you have not specified IDE/Language used. For example, in Mervis IDE you can use the following approach:
        Automatic restart of the 1-Wire bus
        Can you share more info about the application?
