Websocket disconnected
I prefer to run node-red on my raspberry pi with desktop environment.
When I install "node-red-contrib-unipi-evok" and I insert a unipi flow the websocket node doesn't connect:
When I install the "Unipi 1.1 Node-RED OS" image on the SD card and start node-red the websocket works fine:
But in this option I have no desktop environment on my Raspberry Pi.I'm trying to find out why the websocket doesn't work in the node-red installed in the first example with desktop environment.
I don't onderstand way this doesn't work. 😩
How can i fix this problem?
Can anyone help me with this?
Hello @wolge, from the screenshot it looks like you are using two different URLs. The first one is /ws/127.0.0.1:8080 which is incorrect.
