HMI
In the HMI software You can display values of different kind of variables.
There is a possibility to adjust a value with + and - keys.
Is i posible to type in a value?
I want to key in a time at which my lights switch on and of, so by means of a keyboard typing 11:05 for excample.thanks in advance
Frans
Frans
This could be done with the Time program in HMI and also see Schedulers in IDE
Sorry for such a question but could You please tell me where can I download Mervis HMI?
On https://files.unipi.technology/index.php/s/zTmrEbQEvifNd6W?path=%2FMervis I only can see the following directories/files:
Documentation
Example
Lib.UniPi_basic.slb
Library README.txt
MervisIDE_x86_44022.msi
MervisIDE_x86_44317.msi
MervisIDE_x86_45059.msi
unipi-jessie-2015-12-08.gz
the file you are looking for is MervisIDE_x86_44022.msi
Hi again,
I installed MervisIDE_x86_44022.msi as You suggested.
It opened an older version (Build 44022) of the well known Mervis IDE.
I can see screenshots in the application help about "MERBON HMI" and tried to locate the application in the program directories but found only MervisIDE.exe
Sorry for incomprehension...Thanks!
KR,
Szabolcs
Sorry I meant MervisIDE_x86_45059.msi - the bigger the number at the end is, the newer the IDE and HMI is too.
You also need to make sure that you install the HMI during the installation…
Got it, Thanks!
Shame on me!
