    1-Wire pipeline surface temperature sensor
    Scheduled Pinned Locked Moved Other Peripherals
    2 Posts 2 Posters 717 Views
      juntiedt
      I have a question regarding the above mentioned sensor, Does it come as a sensor with 4 wire cable (Data in + Data Out) in order to use it with Unipi HUb?
      • Martin KudláčekM
        Martin Kudláček @juntiedt
        Hello @juntiedt,
        this sensor comes in the 3 wire connection + shielding. You can connect it to the 1-Wire hub, ideally as a last sensor. Please consult the 1-Wire hub pinout https://kb.unipi.technology/en:automation:02-glossary:1wire-hidden
