    Analog inputs read 0 in Codesys
    Scheduled Pinned Locked Moved CODESYS
    2 Posts 1 Posters 1.2k Views
      Arjen
      I would much appreciate some help with the UniPi V1.1 and the Analog inputs that come from the MCP3422 (I2C chip).
      The problem I am experiencing is that even thought the onboard I2C relays work, my analog inputs read ‘0’ when power is applied to the analog inputs.
      I have already tried the following:
      -Editted the /boot/config.txt (dtparam=i2c_arm=on, dtparam=i2c_baudrate=400000) and the rest
      -When this did not work I ran the CODESYS_for_Unipi_Setup.sh on the Pi
      -In the Raspberry Pi It does show a chip with address 0x68 (when using I2Cdetect, this should be the ADC)
      -Cleaned all, then downloaded with Codesys
      For some reason it’s not coming with any values besides 0 in Codesys, but the I2C bus is running, as you can see in the screenshot:
      I am calling the AI1 and AI2 from a PRG file, so it’s not that the analog inputs aren’t accessed by the code.
      Does anyone have a clue as to what I am missing here?
      I know by now that UniPi does not support the codesys analog input implementation from @DavidCozens of COSOSO, and I allready mailed COSOCO support, but maybe someone over here has the same experience..
      any help would be much appreciated
        Arjen
        It seems like the whole connection up to Codesys is fine. When I delete the UniPi_AI I2C module and instead of that insert the MCP3424, I do get data, but it doesn't seem correct. Even if I leave the Unipi AI module and then use the I2C_master.read(16#68, ADR(baReadBufferV), 4); command, it shows data in the buffers that varies when the input voltage is adjusted.. Does anyone have more info on the UniPi_AI I2C chip driver?
