Work Mervis with Unipi 1.0
I Install Mervis both RPI and my computer.
All was work ok until I try to make a task, ( i dont have a license).
in the botom, in task area task o are not highlited.
I try to make a new task but I don succeed
creating multiple tasks is not supported. Instead create programs, like you did, which run in the single task.
Additionally, it seems your current solution is in Simple mode, which does not allow custom modifycation of tasks and programs. That is feature of full mode.
@tomas_hora Thank you!
Hi again,
So I fix the problem.
I continue with "Creating a simple an testing on UNIPI"- In section add Chanel I try to assign Unipi 1.
- a select Link Protocol
- here I try I2C, I'm not sure if it is correct
- I continue from channel with "Add library device"
- In Add Library device I try to select from UniPi (v1.1) to transfer in the right window but I can not.
Please if you have a tutorial with Mervis for UniPI v1.1 please snd it to me or if it not please help me to continue from this phase.
Hello @Tase, we've just relesed an updated version of the Mervis IDE tutorial for Unipi 1 and Lite on https://kb.unipi.technology/en:sw:01-mervis:creating-new-project-on-unipi11-hidden
Hi Tomas,
Thank a lot for your tutorial, it work fine.
Now I will go to the next step to make a project for home automation Managemet of loads in the house. For this project I will use a hybrid power main and fotovoltaic infrastructure.
Now I'm in state to define this project.
Tase
