    One wire how to connect
    • F
      FransSleddens last edited by
      If i read the documentation well, the one wire thermometer is connected via an one-wire IC.
      This IC is connected to the I2C-bus.
      When i configure the I2C-bus, i can't chose the one-wire thermometer.
      Does anyone know how to connect te one-wire thermometer and how to configure it in mervis?
      Kind regards,
      Frans Sleddens
      • F
        Kind regards,
        Frans Sleddens
          Guest last edited by
          You need to create a channel for each bus, you cannot add 1Wire device to different bus. So add a new channel - PlaformIO - 1Wire and than add 1Wire device as you like.
          You only need to add the 8channel 1Wire expander to the I2C bus but not the ONBOARD IC - that runs by default.
          • F
            Hello Thomas,
            thanks for the quick answer.
            Il try it this week.
            Kind regards,
            Frans Sleddens
