    Bugs In Latest Axons
    Ubuntu Core
    228
    • roberts_lando
      Hi everyone. I have just restored an image that I made some months ago using your backup tool. I have made many different axons starting from this USB backup but the new one arrived seems to have some problems. After I restore the backup from the usb the filesystem is not resized and is stucked at 100% use so I cannot do anything.
      How can I fix this?
      Filesystem                                    Size  Used Avail Use% Mounted on
      udev                                          450M     0  450M   0% /dev
      tmpfs                                         100M  2.9M   97M   3% /run
      /dev/disk/by-path/platform-1c11000.mmc-part2  1.4G  1.3G  476K 100% /
      tmpfs                                         498M     0  498M   0% /dev/shm
      tmpfs                                         5.0M     0  5.0M   0% /run/lock
      tmpfs                                         498M     0  498M   0% /sys/fs/cgroup
      tmpfs                                         150M  2.0M  149M   2% /tmp
      tmpfs                                          50M     0   50M   0% /tftpboot
      /dev/mmcblk0p1                                100M   55M   46M  55% /boot
      tmpfs                                         100M     0  100M   0% /run/user/1000
      Also when I try to run a firmware update I get:
      unipi@S105-sn470:~$ /opt/unipi/tools/fwspi -i 0
      Unable to create the arm[0] context
      unipi@S105-sn470:~$ /opt/unipi/tools/fwspi -v --auto
      ARMINIT: Cannot open device /dev/unipispi
      Firmware autoupdate finished
      unipi@S105-sn470:~$
      Also I'm not able to start the axon in Service Web Interface mode (by keep pressing the button while starting). It remains stucked. This also happens with all other axons so the problem is not caused by the restore process but affetcts all axons
      Other info:
      unipi@S105-sn470:~$ sudo fdisk -l
      Disk /dev/mmcblk0: 7.3 GiB, 7818182656 bytes, 15269888 sectors
      Units: sectors of 1 * 512 = 512 bytes
      Sector size (logical/physical): 512 bytes / 512 bytes
      I/O size (minimum/optimal): 512 bytes / 512 bytes
      Disklabel type: dos
      Disk identifier: 0x92824060
      Device         Boot   Start      End  Sectors  Size Id Type
      /dev/mmcblk0p1        49152   253951   204800  100M 83 Linux
      /dev/mmcblk0p2       253952  3098623  2844672  1.4G 83 Linux
      /dev/mmcblk0p3      3098624 15269887 12171264  5.8G 83 Linux
      Disk /dev/mmcblk0boot1: 4 MiB, 4194304 bytes, 8192 sectors
      Disk /dev/mmcblk0boot0: 4 MiB, 4194304 bytes, 8192 sectors
      unipi@S105-sn470:~$
      • roberts_lando
        Actually what I have done is:
        sudo /sbin/fdisk /dev/mmcblk0
        Welcome to fdisk (util-linux 2.29.2).
        Changes will remain in memory only, until you decide to write them.
        Be careful before using the write command.
        Command (m for help): p
        Disklabel type: dos
        Command (m for help): d
        Partition number (1-3, default 3): 3
        Partition 3 has been deleted.
        Partition number (1,2, default 2): 2
        Partition 2 has been deleted.
        Command (m for help): n
        Partition type
           p   primary (1 primary, 0 extended, 3 free)
           e   extended (container for logical partitions)
        Select (default p): 1
        Value out of range.
        Select (default p): p
        Partition number (2-4, default 2): 2
        First sector (2048-15269887, default 2048): 253952
        Last sector, +sectors or +size{K,M,G,T,P} (253952-15269887, default 15269887): 15269887
        Created a new partition 2 of type 'Linux' and of size 7.2 GiB.
        Partition #2 contains a ext4 signature.
        Do you want to remove the signature? [Y]es/[N]o: N
        Disklabel type: dos
        /dev/mmcblk0p2      253952 15269887 15015936  7.2G 83 Linux
        Command (m for help): w
        The partition table has been altered.
        Calling ioctl() to re-read partition table.
        Re-reading the partition table failed.: Device or resource busy
        The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
        unipi@S105-sn470:~$ sudo reboot
        Reboot then:
        unipi@S105-sn470:~$ sudo /sbin/resize2fs /dev/mmcblk0p2
        resize2fs 1.43.4 (31-Jan-2017)
        Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required
        old_desc_blocks = 1, new_desc_blocks = 1
        The filesystem on /dev/mmcblk0p2 is now 1876992 (4k) blocks long.
        Now the partition seems to be ok but some thing aren't working as expected.
        Martin Kudláček 1 Reply Last reply Reply Quote 1
          Martin Kudláček @roberts_lando last edited by
          Hi @roberts_lando,
          the backup2usb tool has some serious flaws, as we discovered last week and we took it down from downloads section. We do not recommend to use it at all. There are couple of things we need to fix first to make it available again.
          • roberts_lando
            @Martin-Kudláček I'm using a customized image of the axon, that was my only way to backup/restore multiple devices in a quick way. How can I do it now?
            I really need this or for me it's almost impossible to work with them. I have spent two days tring to figure out what's happened. I have then created a "restore usb" using this image: https://kb.unipi.technology/en:files:software:os-images:00-start?redirect=1#axon_opensource_os
            Starting from that I have installed all the software needed and created a backup of that but I'm not able to restore it anyway in other axons.
            Also there is a bug in all latest models I have received as no one is able to go in service mode, the run led keeps blink every second and the raws leds never switch on. In able to restore that I have to reset them using the image I previously linked here.
            I will do a refund of all axons I bought If I can't find a fix of this
            • roberts_lando
              If anyone got this issue the main problem was caused by the wrong partition table on some new Axons units.
              In order to be able to restore your backups you have to:
              1. Flash a valid image like https://kb.unipi.technology/en:files:software:os-images:00-start?redirect=1#axon_opensource_os
              2. Connect using ssh to the Axon and follow the steps on my previous comment to resize the partitions correctly (remember, once you fix the partition table to reboot and use the resize2fs command to expand the filesystem
              3. Shutdown your axon and restore the backup
              @Martin-Kudláček I hope that next Axons units will have this bug fixed as it becomes very difficult (and time loss) for me do all this steps in multiple axons
                Hello @roberts_lando,
                the fix is currently in the making.
                • P
                  PhilesG last edited by PhilesG
                  Hello, @roberts_lando. I have a serie of Axon dispatched accross Europe.
                  All the controllers that had been setup around april 2020 using the backup2usb tool have the problem of the Filesystem size. There are about 25 of them.
                  Is the manipulation "safe" to run? Or I might/will loose datas ?
                  The controllers are running a nodeJS application that's doing some logic and sending the datas to our server. There is no 'critical' data on the controller expect the nodeJS piece of code + dependencies.
                  All the controllers are behind a IPSec and the setup don't allow access to internet so if we have to set them up again it would be difficult. I 'just'
                  have SSH control
                  • roberts_lando
                    roberts_lando @PhilesG last edited by
                    @PhilesG The steps (if done correctly) only resize the partition so no data is lost. BTW is something goes wrong it could. I know @Martin-Kudláček also proposed me to create a script to automatically fix the partition problem, I think that would be the safer way
