    Experiences with openHAB?
    OpenHAB
    • K
      knebb2 last edited by
      Hi all,
      I am looking for a control unit for my upcoming smart hone.As I already have a M103 running for my heating (coded it on my own based on C) I prefer to use it for the control unit for smart home.
      I was thinking of using openHAB as it appears to be the most active and stable way for such a unit (tried with NodeRed but this looks really complicated for me) Some years ago I did some first steps in FHEM - I could imagine to get it running...
      Anyway, anyone here who has some experience with openHAB on a Neuron device?
      Thanks!
      /KNEBB
      • K
        knebb last edited by knebb
        just for reference and to help future questions:
        I am running OpenHAB on a dedicated RasPi. It is a Java application which I do not want to run on a Neuron. Keep it simple and stupid.
        In C code it was not too complicated to get data from OpenHAB though curl calls.
        See code snipplet:
        /* Function gets calledd with an item name          */
        /* The url is defined here globally:                */
        /* url="http://openhab.domain.com:8080/rest/items/" */
        long get_2file(char *url, char *filename )
        CURL *curl_handle;
        FILE *FI;
        int r,code;
        code = 0;
        curl_handle = curl_easy_init();
        /* set URL to get here */
        curl_easy_setopt(curl_handle, CURLOPT_URL, url);
        /* disable progress meter, set to 0L to enable and disable debug output */
        curl_easy_setopt(curl_handle, CURLOPT_NOPROGRESS, 1L);
        /* use default write function */
        curl_easy_setopt(curl_handle, CURLOPT_WRITEFUNCTION, NULL);
        /* open the file */
        FI = fopen(filename, "w");
        if(FI) {
                /* write the page body to this file handle */
                curl_easy_setopt(curl_handle, CURLOPT_WRITEDATA, FI);
                /* get it! */
                r = curl_easy_perform(curl_handle);
                if (r != 0) {
                        code=-1;
                } else {
                        /* Data is now in the file */
                /* close the header file */
                r = fclose(FI);
        } else {
                code=-1;
        /* cleanup curl stuff */
        curl_easy_cleanup(curl_handle);
        return code;
