    Weintek MT8051ip > Unipi M203
    3 Posts 2 Posters 1.2k Views
    • John-paulJ
      John-paul
      Hello, I'm new at working with the Unipi PLC in combination with
      a Weintek HMI. I want it to work trough network or RS485. The only thing i want it to do is switch some lamps and a light dimmer (and more in the future). I try to understand the HMI and i got it well working. The only problem is to get the relay output working on the M203. I'm new at working with Mervis IDE. Maybe anyone can help me a bit? I'm working on a unit for a ear/nose doctor for a hospital. Maybe someone in The Netherlands that can help me out remotely? Thnx in regard.
      • Martin KudláčekM
        Martin Kudláček
        Hello John-paul,
        the communication between Axon and Weintek can be over ModbusRTU or BACnet/IP. I strongly recommend to use the latter - BACnet/IP. For both types communications, we have tutorials for configuration in MervisIDE:
        https://kb.unipi.technology/en:sw:01-mervis:weintek-hmi-bacnet-mervis-hidden
        https://kb.unipi.technology/en:sw:01-mervis:weintek-ip-series-hidden
        • John-paulJ
          John-paul
          Hello Martin,
          At this moment i got everything working good with BACnet/IP. It is working very fast. All the buttons are (except the dimmer function) connected to the relay outputs,
          Now i need to programm a dimmer on de M203. I want to use the AO for 1-10 volts to regulate a led dimmer module. I need to find that out, never did that before.
