    nginx not running
      juntiedt last edited by
      I installed evok on rpi4 with buster. One wire, websocket runs ok but I am unable to run the control panel due to nginx problems.
      ● nginx.service - A high performance web server and a reverse proxy server
         Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Thu 2020-02-27 10:18:03 CET; 46s ago
           Docs: man:nginx(8)
        Process: 11233 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
      Feb 27 10:18:03 raspberrypi systemd[1]: Starting A high performance web server and a reverse proxy server...
      Feb 27 10:18:03 raspberrypi nginx[11233]: nginx: [emerg] invalid port in upstream "localhost:" in /etc/nginx/sites-enabled/evok:2
      Feb 27 10:18:03 raspberrypi nginx[11233]: nginx: configuration file /etc/nginx/nginx.conf test failed
      Feb 27 10:18:03 raspberrypi systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
      Feb 27 10:18:03 raspberrypi systemd[1]: nginx.service: Failed with result 'exit-code'.
      Feb 27 10:18:03 raspberrypi systemd[1]: Failed to start A high performance web server and a reverse proxy server.
      Any idea how to fix it without reinstalling evok?
        martin_triska last edited by
        Hello @juntiedt,
        it seems that the evok site configuration file has not a valid content.
        1. What version of Evok are you running?
        2. Did you follow the installation guide on Evok github page (section Legacy installation process using a shell script)? Note that the .deb package installation is not available for Unipi1.1[lite].
        3. Can you send us the content of your /etc/nginx/sites-enabled/evok file?
          juntiedt last edited by juntiedt
          requested file /etc/nginx/sites-enabled/evok file:
          installation legacy with script as on git hub
          installation 2 weeks ago
          upstream evok {
                  server localhost:;
          server {
          	listen  default_server;
          	server_name  _;
          	#ssl on;
          	#ssl_certificate      /etc/nginx/democert.pem;
          	#ssl_certificate_key  /etc/nginx/democert.key;
          	#access_log  /var/log/evok.access.log;
          	access_log  off;
          	root /var/www/evok;
          	location / {
          	    index index.html;
          	location /favicon.ico {
          		alias /var/www/evok/favicon.ico;
          	location /ws {
          		proxy_pass http://evok;
          		proxy_set_header Host $host:$server_port;
          		proxy_http_version 1.1;
          		proxy_set_header Upgrade $http_upgrade;
          		proxy_set_header Connection "upgrade";
          		proxy_buffering off;
          		proxy_cache off;
          		proxy_read_timeout 180;
          	location /rest {
          	location /json {
          	location /bulk {
          	location /rpc {
            OK, now it is a bit clearer. You probably did not insert TCP port while you have been asked for it during the installation process. Default values within the file are:
            upstream evok {
                    server localhost:8080;
            server {
            	listen 80 default_server;
            	server_name  _;
            	#ssl on;
            	access_log  off;
            	root /var/www/evok;
            	location / {
            	    index index.html;
            	location /ws {
            		proxy_cache off;
            	location /rest {
            	location /json {
            	location /bulk {
            	location /rpc {
              Hi Martin,
              thanks for your help and support.
              All running again!
              regards Hannes
