    Comparing online and offline project
    • W
      wzp last edited by
      is there a way to compare and check the differences between the online software on the PLC and the offline software in the MERVIS IDE?
      Thanks.
        Martin Kudláček @wzp last edited by
        Hello @wzp,
        not exactly. You can check if the project is the same - start debugging and if the project on the PLC is different, you will be notified in the Output tab in the bottom panel.
