    6xport 1 wire hub
    General Discussion
    1
      Adriaan last edited by
      Is it right that the 6xport hub comes without a connection wire?
      ( and without the free 1 wire sensor)
      How can i connect the hub to the unipi?
          Guest last edited by
          Hello Adrian.
          We do not sell connection wires right now, but a standard ethernet cat5 cable works well. But we will connection wires and other new accessories to the shop early.
          I checked your order and you purchased 4 sensors.. How many have you received? We do not give any sensors to the hub, it was only available for IndieGoGo contributors…
            Hi Tomas,
            I received 4 sensors.
            When i ordered in the text by the hub was written " 1 free sensor included".
            Anyhow i will try to connect the hub with a ethernet cat 5 wire.
              Ok. I am not aware but I will ask my colleagues if they put it on the product page….
              Anyhow make sure to use straight Ethernet cable, crossover wont work.
              Br,
