unipi-kernel-modules-dkms does not generate modules on upgrade
Unpacking unipi-kernel-modules-dkms (1.36) over (1.34) ... Setting up unipi-kernel-modules-dkms (1.36) ... Loading new unipi-1.36 DKMS files... dpkg: warning: version 'initrd.inc-initrd.inc' has bad syntax: version number does not start with digit dpkg: warning: version 'unipi.inc-unipi.inc' has bad syntax: version number does no t start with digit dpkg: warning: version 'initrd.inc-initrd.inc' has bad syntax: version number does not start with digit It is likely that 4.19.75-v7+ belongs to a chroot's host Building for unipi.inc Module build for kernel unipi.inc was skipped since the kernel headers for this kernel does not seem to be installed. root@basementplc:~# find /lib/modules -iname '*unipi*' root@basementplc:~#
Hello @achilleas-kotsis,
I cannot reproduce it. I took current 2.2.0.20 image and ranapt install unipi-kernel-modules-dkms
. The replacement for unipi-kernel-modules worked out of the box. Can you share a bit more about your setup?Thanks,
Hi @martin-kudláček,
Initial installation of unipi-kernel-modules-dkms or replacing unipi-kernel-modules works. Upgrading unipi-kernel-modules-dkms to a newer version doesn't work.
Using raspbian and packages from https://repo.unipi.technology/debian. Happens on both stretch and buster.
