spi_master spi0: spi0.1: timeout transferring
In the Neuron and AXON I have a lot of the same errors (1000+ per day) in /var/log/messages
Oct 11 14:47:05 control kernel: [183869.394758] spi_master spi0: spi0.1: timeout transferring 4 bytes@12000000Hz for 24(20)ms Oct 11 15:10:30 control kernel: [185274.808880] spi_master spi0: spi0.1: timeout transferring 16 bytes@12000000Hz for 24(20)ms Oct 11 15:20:23 control kernel: [185867.652716] spi_master spi0: spi0.1: timeout transferring 16 bytes@12000000Hz for 24(20)ms
Any idea, how to fix that? Can't find any info in web...
Hi @beergeek,
can you please post what versions of our packages do you use?dpkg -l | egrep "unipi|mervis|evok|axon|neuron"
And also what versions of firmware do you have in the boards:
sudo /opt/unipi/tools/fwspi -i 0
sudo /opt/unipi/tools/fwspi -i 1
sudo /opt/unipi/tools/fwspi -i 2
Thanks,
It was the last year with all versions. Just now want to fix this, because all the logs with these errors. Neuron and AXON have the same latest versions, the difference is only in the packages "axon-kernel-*".
dpkg -l | egrep "unipi|mervis|evok|axon|neuron" ii axon-kernel 4.14.20190801 arm64 transitional package ii axon-kernel-image 1.20190926~stretch arm64 Linux kernel for UniPi Axon controller ii evok 2.1.4~stretch arm64 UniPi API based on the Tornado webserver ii mervis-runtime 2.1.3-9 arm64 Mervis runtime for Arm on Debian systems ii unipi-common 1.2.12~stretch arm64 Common utilities for Unipi/Neuron/Axon ii unipi-firmware 5.40 all Firmware files for UniPi Neuron/Axon boards ii unipi-firmware-tools 1.2.12~stretch arm64 Firmware utilities for UniPi Neuron/Axon controllers. ii unipi-kernel-modules 1.34.1.20190926~stretch arm64 UniPi Neuron/Axon kernel modules ii unipi-mervis-tools 2.1.3.16~stretch all Unipi support tools for Mervis runtime on Debian systems ii unipi-modbus-tools 1.2.12~stretch arm64 Modbus server for UniPi Neuron/Axon controllers.
$sudo /opt/unipi/tools/fwspi -i 0 Boardset: 0 B-1000 (v1.0) Baseboard: 0 B-1000 (v2.0) Firmware: v5.36
$ sudo /opt/unipi/tools/fwspi -i 1 Boardset: 8 E-16Di_U-14Ro (v1.0) Baseboard: 3 E-16Di (v2.0) Firmware: v5.36
sudo /opt/unipi/tools/fwspi -i 2 Unable to create the arm[2] context
Neuron, after apt-get upgrade
$ sudo /opt/unipi/tools/fwspi -i 0 Boardset: 0 B-1000 (v1.0) Baseboard: 0 B-1000 (v0.6) Firmware: v5.27
sudo /opt/unipi/tools/fwspi -i 1 Boardset: 1 E-8Di8Ro (v1.0) Baseboard: 1 E-8Di8Ro (v0.2) Firmware: v5.27
