    3G/4G for Unipi Neuron S103-G available ?
      asunc last edited by
      Unipi Neuron S103-G has only GPRS module, right ? It's a bit too slow for our applications.
      I wonder if there are any plans to integrate a faster 3G or 4G module to Neuron series ?
      This otherwise so great stuff, but falls behind competition in mobile communication now.
        Martin Kudláček @asunc last edited by
        Hello @asunc,
        the active development of Neuron line has finished although the support will be for many years to come. The current line Axon has LTE models: Axon S165, Axon M265 and Axon M565. Those are currently in public testing phase, you can request them at info@unipi.technology.
          I'll probably have to check those out. As far as I understand, those are not RPi / Raspbian based.
          We need couple of things for software (which are currently OK with Neuron based stuff):
          • OS security updates (ie. apt update & apt upgrade should do expected things)
          • Java JRE should work
          We are planning to use these devices to run our existing data collector package (which is java-based). Also, our customers require that Linux-based stuff should have support for OS security updates.
          Can you confirm that these are OK ?
            Hello @asunc,
            absolutely no problem. The Axon is running a debootstraped arm64 Debian with added repository of our packages via which we publish fixes and new versions of our software.
