    UniPi 1.1 Raspberry Pi 4 support
    UniPi 1 - First Generation
    1137
      Dirk last edited by
      will UniPi 1.1 support Raspberry Pi 4 in the future? It's not working at the moment, although I thought there the GPIOs on the new Raspberry Pi are downwards compatible.
      Any help is appreciated.
      Thanks, Dirk
        Martin Kudláček @Dirk last edited by
        Hi @dirk,
        which access to the IOs do you use? Which OS image? The Evok has some troubles running on the Raspbian Buster and the fix is currently in the making.
          Dirk last edited by
          Hi @Martin-Kudláček,
          basically I do not use an API and communicate with the board in Python directly. The software lives in docker containers. I use Raspbian Buster as host system at the moment. Docker container itself still runs on Stretch.
          The latest version of http://wiringpi.com (which supports Pi4) does not work neither. Doesn't catch any change of GPIOs.
          But you would not say, that it shouldn't run at all? I was wondering anyhow, because I thought the GPIOs should be backwards compatible.
          Dirk
            tomas_hora administrators @Dirk last edited by
            @dirk The GPIOs should be compatible. Did you update to the wiringpi? http://wiringpi.com/wiringpi-updated-to-2-52-for-the-raspberry-pi-4b/
              Dirk last edited by
              @tomas_hora yes I'm running the latest wiringpi version 2.5.2.
                Dirk last edited by Dirk
                @Martin-Kudláček @tomas_hora
                I've checked once again and the only pin I was able to read successfully, was
                BCM 4 | wPi 7 | GPIO. 7 | IN
                BCM 7 | wPi 11 | CE1 | IN
                which is
                I01 GPIO04 Digital Input Digital Input
                I08 GPIO07 Digital Input Digital Input
                in your documentation
                  Dirk last edited by
                  And one thing more I discovered. GPIO 34 which is GND toggel randomly between high and low.
                    martin_triska administrators last edited by martin_triska
                    Hello @Dirk,
                    our web-services API EVOK is tested with the RPi4. It uses pigpio library internally. As you mentioned, there are no changes in the GPIOs since previous versions of RPis. Do you have internal pull-ups turned on as mentioned in the manual?
                    Can you please post a schematic of your circuit?
                      Dirk last edited by
                      thank you for your input. The problem were the internal pull-ups, set to low. Usually the python library, I'm using, does this job, but there seems to be a problem with the Raspberry Pi 4. Nevertheless I was able, to get everything up and running again, by setting needed GPIO pull-ups to high via /boot/config.txt. It's not the best solution, because it should be fixed software-wise. But it's the proof, that the problem is not related to hardware. Thank you so much for helping me, figure this out.
                      Dirk
