Relay sharing common "COM"
I have several questions concerning the use of these relays with a common "COM" pin (like RO2.4 / RO2.5).
What are the use cases of these relays? Is it dangerous to use these common relays with outputs having different power supplies?Finally, is it recommended for safety reason to use a different power source between the unipi power supply and the dry contact equipment (in input) ?
Thank you in advance for your reply,
Gabriel -
Hi Gabriel,
You can find most of the information in the articles on inputs and outputs in the products section on our KnowledgeBase.
Below you will find the answers to your questions:
- It depends on the specific circuit connection, but in most cases such a connection is undesirable.
- Yes
@AVsetula Ok perfect thanks you !
A AVsetula locked this topic on
