    jsonrpc get digital input
    12 Posts 2 Posters 6.2k Views
      TomasKnot
      That is very odd! There have been some recent changes to the way Tornado handles subroutines, which should be fixed in the latest Github Master version, but they do not manifest in this way.
      Could you post the code where you call the RPC procedure, and perhaps some information regarding which image you use?
        Juergen
        Hi Thomas
        atached my code:
        Import jsonrpclib
        s = jsonrpclib.Server('http://localhost:8088/rpc')
        st = Server.input_get_value("1_01")
        print("result :", st)
        My tests where:
        1. start my Programm without loaded Webpage, result is always 0
          2)start Webpage
        2. start program again, result is 0 or 1 depending on DI1 is set or not. Ist working
        3. Close the Webpage while DI1 is set
        4. now result is 1, independed of DI1
        So it looks that the actual state of DI1 is stored
          TomasKnot
          I cannot observe the behavior you describe with the latest image and your code (note that I had to decapitalise "Import" to "import" on line 1 and change "Server" to "s" on line 3).
          python rpctest.py
          ('result :', 0)
          python rpctest.py
          ('result :', 0)
          python rpctest.py
          ('result :', 1)
          python rpctest.py
          ('result :', 0)
          python rpctest.py
          ('result :', 1)
          --- At this point I closed the web interface ---
          python rpctest.py
          ('result :', 1)
          python rpctest.py
          ('result :', 0)
          python rpctest.py
          ('result :', 1)
          This is really terribly awkward. I will try to do some more detailed testing in a few hours.
            Juergen
            Hi Thomas,
            that is funny.
            I had tested this with an older Installation based on evok 1.0
            With the new Image it works!
            But if I add
            s.relay_set("1_01",1)
            to my program I get the message:
            File "jhtest2.py", line 5, in <module>
            File "/usr/local/lib/python2.7/dist-packages/jsonrpclib/jsonrpc.py", line 288, in call
            return self.__send(self.__name, args)
            File "/usr/local/lib/python2.7/dist-packages/jsonrpclib/jsonrpc.py", line 239, in _request
            return response['result']
            TypeError: 'NoneType' object has no attribute 'getitem'
              Juergen
              Hi Thomas,
              I found the Problem in an old Forum Topic from october 2015.
              With a modification of jsonrpclib.py it works.
              One last question.
              Is it possible for you to create an Image with a full raspian strech and only the lite Version
              Best regards
              Jürgen
                TomasKnot
                @Juergen
                We cannot provide a full image as it is not fully compatible with our custom drivers. Installing EVOK manually according to the github instructions does not use these drivers though, and as such can be used with Raspbian Stretch full.
                Keep in mind that running a heavy load on the RPi CPU can cause the device to respond more slowly or less reliably.
                  Juergen
                  Ok,
                  I use your image
                    Juergen
                    Hi Thomas,
                    if I start my program
                    import jsonrpclib
                    s=jsonrpclib.Server('http://localhost:8080/rpc')
                    re="1_01"
                    s.relay_set("1_01",0)
                    s.relay_get("1_01")
                    spstatus=s.input_get_value('1_01')
                    print("sp:", spstatus)
                    It works, I can set the relay and also read the DI, but I found the following error:
                    relay_set
                    [I 180314 17:41:14 web:2063] 200 POST /rpc (::1) 4.82ms
                    [E 180314 17:41:14 concurrent:129] Future exception was never retrieved: Traceback (most recent call last):
                    File "/usr/local/lib/python2.7/dist-packages/tornadorpc_evok/base.py", line 195, in post
                    self.finish(response_text)
                    File "/usr/local/lib/python2.7/dist-packages/tornado/web.py", line 962, in finish
                    raise RuntimeError("finish() called twice")
                    RuntimeError: finish() called twice
                    relay_set
                    [I 180314 17:41:14 web:2063] 200 POST /rpc (::1) 49.89ms
                    input_get_value
                    [I 180314 17:41:14 web:2063] 200 POST /rpc (::1) 45.27ms
                    Maybee this could help you with my other problem
                      TomasKnot
                      This is a known issue with some older versions of EVOK, you can use the fix from https://github.com/UniPiTechnology/evok/commit/a19b057ffc3281b1ca807b66bb4c60e0cd62956a (only thing needed is to uncomment one line). I believe that this should be fixed on the newer images - is it not?
                      It occurs because an update to the Tornado-RPC library we are using broke compatibility, though thankfully only in a minor way.
                        Juergen
                        Hi Thomas,
                        now it works without an error.
                        I used the the Image from 9. of march.
                        You should also modify /usr/local/lib/python2.7/dist-packages/jsonrpclib/jsonrpc.py
                        to avoid the error "getitem" I postd 3 days ago.
                        1- sudo nano /usr/local/lib/python2.7/dist-packages/jsonrpclib/jsonrpc.py
                        2- Press "Strg + w" to search for "return response['result']"
                        3- edit
                        def _request(self, methodname, params, rpcid=None):
                        request = dumps(params, methodname, encoding=self.__encoding, rpcid=rpcid, version=self.__version)
                        response = self._run_request(request)
                        check_for_errors(response)
                        to
                        if response == None:
                        return response
                        else:
                        5- Press "Strg + x" to exit
                        6- Finish ;)
                        Thank you very much
                        Jürgen
                          TomasKnot
                          I'm surprised the
                          line doesn't catch it. Either way thanks for the fix, we'll include it in the next commit!
                          Happy to hear that it works for you now.
