    sedtronic light intensity sensor
    8504
      juntiedt last edited by
      HiTomas,
      in the library, that I mentioned above, they called Vcurr just I which means current. As sedtronic said, I = 0 means 0% and I=0,250 mens 100%. Knowing this, I don't care about the resistor.
      Also have a look at the many conversation calculations in the library above. Actualy one can read the code for the formula from the 1w device.
        You should be able to use the latest owclient.py to read the VCurr/VIS value. After a call to Mr. Sedlacek, the value and calculation is the same, just the naming scheme is different.
        To be clear I should note VIS is not I, but rather voltage delta between the two VSens inputs into ds2438 (http://pdf1.alldatasheet.com/datasheet-pdf/view/58618/DALLAS/DS2438.html). To compute I one does in fact need the resistor value.
        I did have a look at the website you sent me, but while interesting it a) does not have all the sensors that can be connected to the DS2438 and b) 1Wire does not have any way of identifying which sensors are connected to it, which means the user would have to specify which formula to use anyhow.
        Apologies for it being so difficult to read the value. The sensor has been primarily tested with Mervis rather than EVOK.
          i just changed owclient.py in /opt/evok/ but had no success. The http Client interface crashes when now reading ds2438 device.
            TomasKnot @juntiedt last edited by TomasKnot
            @juntiedt
            That's odd. I haven't had that happen myself when I tested the change. In fact the client interface does not read any of the sensor data aside from temperature and humidity, here:
            case "1wdevice": {
            	if (device_properties["typ"] == "DS2438") {
            		device_properties["device_name"] = "" + device_properties["typ"] + " - " + circuit_display_name;
                    if (msg.value == null) {
                    	device_properties["value"] = "N/A";
                    	device_properties["humidity"] = "N/A";
                    else {
                    	device_properties["value"] = msg.temp.toFixed(1);
                    	device_properties["humidity"] = msg.humidity.toFixed(1);
                    	device_properties["unit"] = "°C";
            	} else {
            		device_properties["device_name"] = "Sensor " + device_properties["typ"] + " - " + circuit_display_name;
                    else {
                    	device_properties["value"] = msg.value.toFixed(1);
            	break;
            When you say it crashes, what do you mean exactly?
              this is what I get with the new owclient.py when calling temp device:
              {'code': 500, 'status': 'error', 'message': 'Internal Server Error'}
              All other devices are ok
                TomasKnot last edited by
                I've now pushed a fix for the display issue. The device type of the DS2438 has been changed to temp, but the interface which verifies the requests wasn't updated properly for it, and the GUI had trouble dealing with it as well.
                Replacing the devices.py (in /opt/evok) and main.js (in /var/www/evok/js/) with the latest versions should do the trick now.
                  thanks for your fast response, but that's what I get now:
                    File "/home/pi/part_10/webapp/UniPi_devices.py", line 9, in <module>
                      records = unipi.get_all_devices("j")
                    File "/home/pi/part_10/webapp/UniPi_interface_class.py", line 56, in get_all_devices
                      res = urllib.request.urlopen(url_rest).read()
                    File "/usr/lib/python3.5/urllib/request.py", line 163, in urlopen
                      return opener.open(url, data, timeout)
                    File "/usr/lib/python3.5/urllib/request.py", line 472, in open
                      response = meth(req, response)
                    File "/usr/lib/python3.5/urllib/request.py", line 582, in http_response
                      'http', request, response, code, msg, hdrs)
                    File "/usr/lib/python3.5/urllib/request.py", line 510, in error
                      return self._call_chain(*args)
                    File "/usr/lib/python3.5/urllib/request.py", line 444, in _call_chain
                      result = func(*args)
                    File "/usr/lib/python3.5/urllib/request.py", line 590, in http_error_default
                      raise HTTPError(req.full_url, code, msg, hdrs, fp)
                  urllib.error.HTTPError: HTTP Error 502: Bad Gateway
                  Hope the problem is not to bad ...
                    I tested it with a clean Raspberry Pi image using the latest GH master. You shouldn't need to use a clean image, however; it was more to check that everything else works as it should.
                    It might help if you replace all of EVOK source code with the latest version (i.e. the .py files, evok.py and schemas.py in particular). I've tested both the REST and WebSocket API so it should work. The error could be from verification code in evok.py/schemas.py, where if you use a newer version of the other files they fail to work properly together.
                      after reinstalling evok everything is ok!
                      Many thanks for your professional support.
                      have alook at my trainings unipi control panel 188.194.138.174
                      temp devices get updated every minute and the other devices uses evok websocket events.
                      Hannes
                        @juntiedt said in sedtronic light intensity sensor:
                        Hannes
                        That looks really excellent! Glad you got it working well now.
                        Apologies for the issues with EVOK.
                        Kind Regards
                        Tomas
