    EVOK configure additional 1wire port
    3 Posts 2 Posters 2.3k Views
    • L
      lukec
      i'm trying to add additional 1-wire port to evok (unipi v1.1), by adding usb-1wire converter.
      In evok.conf I defined second OW bus by adding:
      [OWBUS_2]
      bus = /dev/ttyUSB0
      interval = 5
      scan_interval = 300
      but I cannot read any sensors. Any help wil be appriciated.
      BR
        TomasKnot
        Try putting in "-d" (sans the quotes) in front of the /dev/ttyUSB0, i.e. bus = -d /dev/ttyUSB0
        Another option would be try putting in just "u". (sans the quotes again)
        Unfortunately I cannot guarantee that this will work, as we use an external OWFS server to implement our 1Wire support, which means that unless the device behaves correctly with it it will not function in evok without custom driver support.
        • L
          lukec
          Tomas,
          thank you, putting "-d" in front (bus = -d /dev/ttyUSB0) worked - maybe you could update the evok.conf file with this (as example)
          BR
