    evok doesn't work without a network connection
    6 Posts 2 Posters 3.7k Views
      coopi
      I'll use the UNIPI board in combination with evok without any network connection but when I separate the UNIPI board from my network I get the error message Network is unreachable.
      In my network everything works fine.
      I use the relay outputs and the digital input.
      Is there a way to use the UNIPI board with evok, or another API, on an island without any network connection?
      Kind regards
      coopi
        Merv
        I've not had that problem, and my Unipi/Pi are regularly not on the network. Where do you see this error showing up? What effect does it have on your system?
        Merv.
          coopi
          There are some python scripts which report errors.
          For example socket.py and _core.py within the python 2.7 library.
          How did you config your PI?
          Did you setup a static IP address and if so where?
          coopi
          M 1 Reply Last reply
            Merv @coopi
            @coopi
            I cannot recall in detail, but I am connecting wirelessly to a router. The router runs dhcp, and therefore the Pi gets whatever address it is given. The router is often powered off, and when it powers back on the Pi can get a different address which makes it fun trying to find it again.
            On the pi, I'm running a Python program that reads the inputs and sets the outputs for controlling lights. As that's the only script I'm running, I do not see any errors when it's disconnected from the network. In the background, the evok script also runs, and when it's connected to the network I can access it using my phone and turn the relays on and off etc. but I never see the error you describe.
            Merv.
              coopi
              To get the digital input status i use a callback function in my python script.
              You wrote you read the input.
              Which function you use to read the digital input?
              coopi
                coopi
                I found the problem.
                In one of the scripts I used the IP address which was assigned by the router before.
                I substituted it with the localhost address 127.0.0.1 and all works fine.
                @Merv, thanks for your help!
                Kind regards
                coopi
                Reply Quote 1
