    Unable to get xS30 extension working on the Neuron M103
    1
    917
    • P
      phillipsnick last edited by
      Running Evok release v2.0.7h
      On a fairly recent version of Debian Stretch from the Raspberry Pi website.
      uname -a
      Linux M103-sn25 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
      Main modules inputs/outputs are working just fine within the Evok HTTP interface.
      Following the setup instructions by @TomasKnot here https://forum.unipi.technology/topic/652/how-to-add-xs40-to-neuron-l203-using-custom-software/12 I now have the following:
      /etc/evok.conf
      [MAIN]									; !!! ALL MAIN SECTION OPTIONS ARE MANDATORY !!!
      config_version = 2.5					; Configuration file version, DO NOT CHANGE!
      use_schema_verification = False			; Enabling this will deny any requests that do not match the JSON Schema; NOTE THAT THIS RESULTS IN A SIGNIFICANT INCREASE IN LATENCY AND SHOULD NOT BE USED EXCEPT FOR TESTING
      log_level = ERROR   					; Minimum severity of messages to be logged; one of INFO, DEBUG, WARNING, ERROR, CRITICAL
      log_file = /var/log/evok.log			; Log file to use; will be cleared on boot
      port = 8080								; !!! Internal API port - only change if you are certain you know what you are doing; FOR OUR WEB INTERFACE THE PORT SHOULD BE CHANGED IN "/etc/evok-nginx.conf" INSTEAD !!!
      webhook_enabled = False					; Enables webhook notification - see e.g. https://sendgrid.com/blog/whats-webhook/
      webhook_address = http://127.0.0.1:80   ; Put your server endpoint address here (e.g. http://123.123.123.123:/wh )
      webhook_device_mask = ["input","wd"]	; List of device types to notify on (written as a JSON list) - adding AI will generate a large amount of messages!
      webhook_complex_events = False			; EVOK will send POST requests with the same data as WebSocket, rather than an empty GET request
      wifi_control_enabled = False			; !!! REQUIRES THE UNIPIAP WIFI CONTROLLER TO BE INSTALLED !!! Will allow evok to control the internal Neuron wifi
      soap_server_enabled = False				; Enables the simple SOAP server; use only if you need the functionality
      soap_server_port = 8081					; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. different from the port setting above) !!!
      [NEURON_1]
      global_id = 1							; Mandatory, REQUIRED TO BE UNIQUE
      allow_register_access = False 			; Optional, False default
      scan_frequency = 10						; Optional, 10 default, scanning frequency in [Hz]
      scan_enabled = True 					; Optional, True default
      ; Below you can find examples for connecting devices over UART; first example is a Neuron extension while the second is a custom third-party device
      ; Devices sharing a port use the port settings of the first device on that port (baud rate, parity, stop bits)
      ; !!! Note that device_name has to match a filename in the /etc/hw_definitions directory !!! See /etc/hw_definitions/CUSTOM MODBUS DEVICE.yaml for an example
      [EXTENSION_1]
      global_id = 2							; Mandatory, REQUIRED TO BE UNIQUE
      device_name = xS30						; Mandatory
      modbus_uart_port = /dev/extcomm/0/0 	; Mandatory
      neuron_uart_circuit = 1_01				; Optional, allows associating extensions with specific Neuron UART-over-Modbus ports (not possible for non-Modbus UART ports, e.g. /dev/ttyUSB0 or /dev/ttyS0)
      ;allow_register_access = True 			; Optional, False default, is mandatory with third-party devices
      address = 1							; Optional, 1 default
      ;scan_enabled = True 					; Optional, True default
      baud_rate = 19200						; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      parity = N								; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      stop_bits = 1							; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      Wiring
      RS485-A connects to RS485-A
      RS485-B connects to RS485-B
      Rebooted everything and the TX light on the UniPi occasionally flashes but nothing on the extension.
      No additional devices available in the HTTP interface.
      Tried to run the debug here:
      /usr/bin/python /opt/evok/evok.py --path1=/etc/evok.conf --path2=/etc/evok-neuron.conf
      /usr/bin/python: can't open file '/opt/evok/evok.py': [Errno 2] No such file or directory
      Found this under /opt/evok/lib/python2.7/site-packages/evok/evok.py and adjusted the command to
      /usr/bin/python /opt/evok/lib/python2.7/site-packages/evok/evok.py --path1=/etc/evok.conf
        File "/opt/evok/lib/python2.7/site-packages/evok/evok.py", line 5, in <module>
          import tornado.httpserver
      ImportError: No module named tornado.httpserver
      Anyone got any ideas on what I can try to debug this further? :)
