    Bug with unipi extensions / only Adress 0 work!
    • B
      burnscm last edited by
      Neuron L403 S/N: 02
      xS10 S/N: 85
      xS10 S/N: 86
      unipian (new)
      I have tested various adresses. Only one Extension works on adress 0 !
      evok.conf
      [MAIN]        ; !!! ALL MAIN SECTION OPTIONS ARE MANDATORY !!!
      config_version = 2.5                                    ; Configuration file version, DO NOT CHANGE!
      use_schema_verification = False                 ; Enabling this will deny any requests that do not match the JSON Schema; NOTE THAT THIS RESULTS IN A SIGNIFICANT INCREASE IN LATENCY AND SHOULD NOT BE USED EXCEPT FOR TE$
      log_level = ERROR                                       ; Minimum severity of messages to be logged; one of INFO, DEBUG, WARNING, ERROR, CRITICAL
      log_file = /var/log/evok.log                    ; Log file to use; will be cleared on boot
      port = 8080                                                             ; !!! Internal API port - only change if you are certain you know what you are doing; FOR OUR WEB INTERFACE THE PORT SHOULD BE CHANGED IN "/etc/ev$
      webhook_enabled = False                                 ; Enables webhook notification - see e.g. https://sendgrid.com/blog/whats-webhook/
      webhook_address = http://127.0.0.1:80   ; Put your server endpoint address here (e.g. http://123.123.123.123:/wh )
      webhook_device_mask = ["input","wd"]    ; List of device types to notify on (written as a JSON list) - adding AI will generate a large amount of messages!
      webhook_complex_events = False                  ; EVOK will send POST requests with the same data as WebSocket, rather than an empty GET request
      wifi_control_enabled = False                    ; !!! REQUIRES THE UNIPIAP WIFI CONTROLLER TO BE INSTALLED !!! Will allow evok to control the internal Neuron wifi
      soap_server_enabled = False                             ; Enables the simple SOAP server; use only if you need the functionality
      soap_server_port = 8081                                 ; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. different from the port setting above) !!!
      [NEURON_1]
      global_id = 1                                                   ; Mandatory, REQUIRED TO BE UNIQUE
      allow_register_access = False                   ; Optional, False default
      scan_frequency = 10                                             ; Optional, 10 default, scanning frequency in [Hz]
      scan_enabled = True                             ; Optional, True default
      [EXTENSION_1]
      global_id = 2
      device_name = xS10
      modbus_uart_port = /dev/extcomm/0/0
      neuron_uart_circuit = 1_01
      ;allow_register_access = True
      address = 0
      scan_frequency = 1
      scan_enabled = True
      [EXTENSION_2]
      global_id = 3
      device_name = xS10
      address = 15
      scan_frequency = 1
      scan_enabled = True
      RX LED flashes on both
      TX LED flashes only on Adress 0 !!
      RUN: on Adress 0 fast flashes
      on Adress 15 slow blinking
      logfile
        File "/opt/evok/lib/python2.7/site-packages/evok/neuron.py", line 61, in get_register
          raise Exception('No cached value of register %d on unit %d - read error' % (counter, unit))
      Exception: No cached value of register 1026 on unit 9 - read error
      2019-05-05 13:44:44,156 - evok - ERROR - No cached value of register 1026 on unit 15 - read error
        File "/opt/evok/lib/python2.7/site-packages/evok/neuron.py", line 343, in readboards
          yield board.parse_definition(self.hw_dict, 1)
        File "/opt/evok/local/lib/python2.7/site-packages/tornado/gen.py", line 1055, in run
          value = future.result()
        File "/opt/evok/local/lib/python2.7/site-packages/tornado/concurrent.py", line 238, in result
          raise_exc_info(self._exc_info)
        File "/opt/evok/local/lib/python2.7/site-packages/tornado/gen.py", line 1069, in run
          yielded = self.gen.send(value)
        File "/opt/evok/lib/python2.7/site-packages/evok/neuron.py", line 625, in parse_definition
          self.parse_feature(m_feature, board_id)
        File "/opt/evok/lib/python2.7/site-packages/evok/neuron.py", line 601, in parse_feature
          self.parse_feature_di(max_count, m_feature, board_id)
        File "/opt/evok/lib/python2.7/site-packages/evok/neuron.py", line 467, in parse_feature_di
          regpolarity=m_feature['polar_reg'], legacy_mode=self.legacy_mode)
        File "/opt/evok/lib/python2.7/site-packages/evok/neuron.py", line 1464, in __init__
          curr_ds = self.arm.neuron.modbus_cache_map.get_register(1, self.regmode, unit=self.arm.modbus_address)[0]
      Exception: No cached value of register 1026 on unit 15 - read error
      2019-05-05 13:44:47,154 - evok - ERROR - No cached value of register 1026 on unit 14 - read error
      Exception: No cached value of register 1026 on unit 14 - read error
      2019-05-05 13:47:06,184 - evok - ERROR - No cached value of register 1026 on unit 15 - read error
      2019-05-05 13:47:09,172 - evok - ERROR - No cached value of register 1026 on unit 14 - read error
      2019-05-05 13:50:03,202 - evok - ERROR - No cached value of register 1026 on unit 14 - read error
      2019-05-05 13:50:06,190 - evok - ERROR - No cached value of register 1026 on unit 15 - read error
      2019-05-05 13:53:57,200 - evok - ERROR - No cached value of register 1026 on unit 15 - read error
      • B
        i fond the problem. the party setting was false!
          Martin Kudláček @burnscm last edited by
          Hello @burnscm,
          moreover, the Modbus doesn't allow to have address 0 and you cannot set the address 0 via our DIP switches. When the DIP switches are in "0" position, the extension uses the address which is stored in the NVRAM, which, by default, is 15.
