MQTT to unipi Control Panel
This is the flow for my unipi control panel. For testing reasons I have connected analog out to analog in2 and relay 6 to input 8 and input 4 to 12 volt. The panel allows you to switch all singele relays as well as all together. A slider set the voltage which you can read on a gauge. (Voltmeter :-)). If anyone has ideas for improvements please let me know.
As the flow is to big to upload I am just sendig a picture. Let me know if you want to get the flow directly.
Hi @juntiedt thats looks nice can/will you send me the flow per PM thx
Regards
hi UNIX, I would share the flow with you. Unfortunately I don't find an option for private message. Can you help me?
hi @juntiedt seems like this forum have no pm funktion please drop me a mail unix@from-hell.org
Regards
@juntiedt said in MQTT to unipi Control Panel:
Hi @juntiedt, it looks like a very great job! Could you consider hosting the file and provide a public link? You might for instance use a Dropbox / pCloud public link, or a GitHub gist.
I think it might be possible to parametrize the flows with variables, in order to avoid repetition. At least, it seems it was done this way by @Jan-Teunis here:
https://forum.unipi.technology/topic/735/node-red-flow-evok-to-mqtt-to-evok
