    Ethernet ports UDP TC
    UniPi 1 - First Generation
    • F
      francoisd last edited by
      In order to install Unipi 1.1 in a different VLAN than my PC, I need the list of IP ports TCP and UDP to open in my firewall.
      Does anybody can give me this list of ports used between Raspberry (Unipi 1.1) and Mervis IDE?
      Thanks in advance.
      François
        Martin Kudláček @francoisd last edited by
        Hello @francoisd,
        the ports are:
        TCP/12346 - For uploading solution
        TCP/80 - For Web HMI
        That should be all. TCP/22 for SSH is handy to have. If you are planning to run ModbusTCP slave in Mervis, then you have to allow another port as well.
        For outgoing communication there should be access to internet via:
        TCP/80 - For MervisDB
        TCP/6677 - For Mervis Proxy
        • F
          Hello Martin,
          Thank you very much.
          I think there is also an UDP port to find PLC (UDP Broadcast). Whitch one is it?
          Best regards
          François
