    Working with EVOK API for the first time
    25 Posts 2 Posters 14.6k Views
      thiagoralves
      I've tried the steps on a blank new Raspbian image and encountered the same error while trying to install neuron-kernel:
      root@raspberrypi:/home/pi# apt-get install neuron-kernel
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      The following packages have unmet dependencies:
       neuron-kernel : Depends: raspberrypi-kernel (= 1.20180919-1) but 1.20180924-1 is to be installed
      E: Unable to correct problems, you have held broken packages.```
        TomasKnot
        Apologies, it looks like you will have to use
        apt-get install unipi-kernel-modules-dkms
        instead of
        this will install the module from source, rather than using a precompiled binary.
        The rest of the instructions should work fine. At any rate - we should release a new version tomorrow which should have the bug fixed.
          thiagoralves
          Hi Tomas, did you guys released the new UniPian image with the driver fix? If yes, I would like to test it with the OpenPLC driver.
          Thanks!
            TomasKnot
            Hi @thiagoralves,
            Apologies for the late reply, I was on sick leave for a while.
            It looks like we still haven't released the image, but I'll try poking the people who take care of it a bit. The package installation should now work, however.
              thiagoralves
              Alright, thanks! I'll try the package installation on Raspbian and report back if I have any issues.
