Neuron unstable when accessing /sys
Thanks again! currently set to minutely and uptime is at 15hrs.
Looks it is really stable now.
thanks again for the great support!
@knebb
If you need faster response times on the SYSFS I can make that change specifically for you, but the limiting factor will be snmp anyhow. Currently SYSFS is set to refresh at a rate of 50Hz. Rates up to 1000Hz are possible in theory, at a cost of higher CPU use. -
Ah, well. No I am absolutely fine with this.
My Cacti monitors the system every 5 minutes. So no need for faster- I am fine with a minute.
Thanks again!
Oh, and it is working stable. Now running for nearly 2days without a reboot.
