    RTC - UniPian - Codesys
    Scheduled Pinned Locked Moved CODESYS
    4 Posts 2 Posters 3.3k Views
    • O
      OlivierP
      Hi all,
      As the Neuron has a RTC, do you need to configure anything on the UniPian or is everything already set-up?
      Is there a specific procedure to follow to change the system-time?
      What is your preferred method to read/out and use the RTC in a PLC program using Codesys. (I need it for a function that only runs between 0-20minutes of 16hours a day, for instance) -> I made a program like this before that ran on the Raspberry, but I'm sure it can be easier...
      I will share the code tomorrow of what I had so far. Thank you.
        DavidCozens
        CODESYS for Raspberry Pi uses the underlying Raspbian (UniPian) operating system to access the RTC. The library DTUtils provides the utilities to access time and date from within CODESYS.
        • O
          OlivierP
          Thx, it's working now.
          • O
            OlivierP
            Sharing the way I solved it, feel free to comment.
