    1-Wire rpc Problem
      Raph7454 last edited by
      I am un Unipi V1.1 User and I would like using 1-Wire devices with python scripts.
      It doesn't work !
      Here is my script and the error :
      from jsonrpclib import Server
      s=Server("http://127.0.0.1/rpc")
      s.owbus_scan(1)
      File "<pyshell#2>", line 1, in <module>
      s.owbus_scan(1)
      ProtocolError: (-32603, u'Internal Error')
      However, in the web interface, the Device DS18S20 works perfectly.
      Thank you for your help !
        Hi @Raph7454!
        The 1Wire RPC interface isn't properly backported to the UniPi 1.1. That said I have now made the necessary changes to make it work. You will need to reinstall your image before the changes come up.
        I hope this clears it up for you,
        Kind Regards
          Hi Tomas !
          Thank you so much for your help
          I work with Raspberry PI 3 and Raspbian Stretch 9.4.
          I have installed Evok two weeks ago.
          What do you mean about "image" please, can I just make a manually re-install of Evok API ? what's the best way to do that please ? I am a beginner with Linux OS..
          I see your files : "tknot Fixed 1Wire RPC for UniPi 1.1" in https://github.com/UniPiTechnology/evok/tree/master/evok
          Best regards
            Hi @Raph7454,
            Yes you will need to reinstall EVOK. Please use a clean Raspbian installation if possible, which is to say reinstall both EVOK and Raspbian.
            EVOK makes a number of changes to Raspbian, and installing it twice on the same installation can potentially cause issues.
            Kind Regards,
