    ERROR:websocket:error from callback
    • Peter Brandt
      Peter Brandt last edited by
      i cant read the event messages from the evok client. All i get is always that error message
      ERROR:websocket:error from callback <function on_message at 0xb67882b0>: string indices must be integers
      import websocket
      import json
      import logging
      #import time
      logging.basicConfig()
      # Replace this with your Neuron IP Address
      url = "ws://127.0.0.1:8080/ws"
      def on_message(ws, message):
              obj = json.loads(message)
              for single_obj in obj:
                      dev = single_obj['dev']
                      circuit = single_obj['circuit']
                      value = single_obj['value']
                      print "Value: " + str(value) + " Device: " + str(dev) + " Circuit: " + str(circuit)
              print message
      def on_error(ws, error):
              print error
      def on_close(ws):
              print "Connection closed"
      def on_open(ws):
      # Turn on filtering
              #ws.send('{"cmd":"filter", "devices":["ai","input",output]}')
              #ws.send(json.dumps({"cmd":"filter", "devices":["ai", "output"]}))
      # Turn on DO 1.01
              ws.send(json.dumps({"cmd":"set", "dev":"relay", "circuit": "1", "value":0}))
              ws.send(json.dumps({"cmd":"set", "dev":"relay", "circuit": "2", "value":0}))
      # Query for complete status
              ws.send(json.dumps({"cmd":"all"}))
      #receiving messages
      ws = websocket.WebSocketApp(url, on_open = on_open, on_message = on_message, on_error = on_error, on_close = on_close)
      ws.run_forever()
      The "cmd" "all" works fine at the first start
      Value: 0 Device: input Circuit: 11
      Value: 0 Device: input Circuit: 10
      Value: 0 Device: input Circuit: 12
      Value: 0 Device: input Circuit: 3
      Value: 0 Device: input Circuit: 2
      Value: 0 Device: input Circuit: 5
      Value: 0 Device: input Circuit: 4
      Value: 0 Device: input Circuit: 7
      Value: 0 Device: input Circuit: 6
      Value: 0 Device: input Circuit: 9
      Value: 0 Device: input Circuit: 8
      Value: 0 Device: relay Circuit: 1
      Value: 0 Device: relay Circuit: 3
      Value: 0 Device: relay Circuit: 2
      Value: 1 Device: relay Circuit: 5
      Value: 0 Device: relay Circuit: 4
      Value: 1 Device: relay Circuit: 7
      Value: 1 Device: relay Circuit: 6
      Value: 0 Device: relay Circuit: 8
      Value: 0.000695620415538 Device: ai Circuit: 1
      Value: 0.000956478071364 Device: ai Circuit: 2
      Can someone help me please ?
        Does the web interface function correctly? It is based on the same websocket listening process and so it should exhibit the same behavior.
        I've tested your code (copy-paste into a python file called wstest.py) on the latest UniPi opensource distribution (essentially just debian with kernel drivers, which only improve UART functionality as far as EVOK is concerned) and it functions as expected, with the following output:
        Value: 0 Device: input Circuit: 1_01
        Value: 0 Device: input Circuit: 1_02
        Value: 0 Device: input Circuit: 1_03
        Value: 0 Device: input Circuit: 1_04
        Value: 0 Device: relay Circuit: 1_01
        Value: 1 Device: relay Circuit: 1_02
        Value: 1 Device: relay Circuit: 1_03
        Value: 0 Device: relay Circuit: 1_04
        Value: 0.00772160933422 Device: ai Circuit: 1_01
        Value: 2.29423873804 Device: ao Circuit: 1_01
        [{"counter_mode": "Enabled", "counter_modes": ["Enabled", "Disabled"], "glob_dev_id": 1, "dev": "input", "ds_modes": ["Simple", "Inverted", "Toggle"], "modes": ["Simple", "DirectSwitch"], "ds_mode": "Simple", "debounce": 50, "counter": 0, "value": 0, "mode": "DirectSwitch", "circuit": "1_01"}, {"counter_modes": ["Enabled", "Disabled"], "glob_dev_id": 1, "modes": ["Simple", "DirectSwitch"], "value": 0, "circuit": "1_02", "debounce": 50, "counter": 0, "counter_mode": "Enabled", "dev": "input", "mode": "Simple"}, {"counter_modes": ["Enabled", "Disabled"], "glob_dev_id": 1, "modes": ["Simple", "DirectSwitch"], "value": 0, "circuit": "1_03", "debounce": 50, "counter": 0, "counter_mode": "Enabled", "dev": "input", "mode": "Simple"}, {"counter_modes": ["Enabled", "Disabled"], "glob_dev_id": 1, "modes": ["Simple", "DirectSwitch"], "value": 0, "circuit": "1_04", "debounce": 50, "counter": 0, "counter_mode": "Enabled", "dev": "input", "mode": "Simple"}, {"glob_dev_id": 1, "modes": ["Simple", "PWM"], "value": 0, "circuit": "1_01", "pending": false, "relay_type": "digital", "dev": "relay", "mode": "Simple"}, {"glob_dev_id": 1, "modes": ["Simple", "PWM"], "value": 1, "circuit": "1_02", "pending": false, "relay_type": "digital", "dev": "relay", "mode": "Simple"}, {"glob_dev_id": 1, "modes": ["Simple", "PWM"], "value": 1, "circuit": "1_03", "pending": false, "relay_type": "digital", "dev": "relay", "mode": "Simple"}, {"glob_dev_id": 1, "modes": ["Simple", "PWM"], "value": 0, "circuit": "1_04", "pending": false, "relay_type": "digital", "dev": "relay", "mode": "Simple"}, {"glob_dev_id": 1, "unit": "V", "value": 0.007721609334224814, "circuit": "1_01", "range_modes": ["10.0"], "modes": ["Voltage", "Current"], "range": "10.0", "dev": "ai", "mode": "Voltage"}, {"modes": ["Voltage", "Current", "Resistance"], "value": 2.2942387380392786, "glob_dev_id": 1, "dev": "ao", "circuit": "1_01", "unit": "V", "mode": "Voltage"}]
        Value: 0 Device: wd Circuit: 1_01
        [{"circuit": "1_01", "value": 0, "glob_dev_id": 1, "dev": "wd", "timeout": 6000, "was_wd_reset": 0, "nv_save": 0}]
        Value: 0.00511440622282 Device: ai Circuit: 1_01
        [{"glob_dev_id": 1, "unit": "V", "value": 0.005114406222816542, "circuit": "1_01", "range_modes": ["10.0"], "modes": ["Voltage", "Current"], "range": "10.0", "dev": "ai", "mode": "Voltage"}, {"circuit": "1_01", "value": 0, "glob_dev_id": 1, "dev": "wd", "timeout": 6000, "was_wd_reset": 0, "nv_save": 0}]
        [{"glob_dev_id": 1, "unit": "V", "value": 0.007721609334224814, "circuit": "1_01", "range_modes": ["10.0"], "modes": ["Voltage", "Current"], "range": "10.0", "dev": "ai", "mode": "Voltage"}]
        It would be helpful if you could post the output of "print obj" and "print message", inserted after the first line of the on_message function, as well as which distribution of EVOK you are using and which version of python.
        e: Added the output of the "all" which I've omitted at first.
