    Unable to connect 1wire temp-sensors, how to configure 1wire interface?
    1
    • S
      Sacirovic last edited by Sacirovic
      I am not able to connect any number of DS18B20-sensors (single one straight to the port or through the 1wire 8port hub).
      I'm using the pinout as described on: https://www.unipi.technology/tutorial/topology-of-1-wire-network-46
      It seems strange to me that even with nothing connected i see the below:
      pi@unipi:/sys/bus/w1/devices $ ls
      00-7a0000000000  00-ba0000000000  w1_bus_master1
      The seem to be dummy devices as their id's change over time, both of them missing the w1_slave-file
      it makes me think that I'm missing a configuration step, i am however unable to find any notion what i need to configure.
      The UniPi M20x is corrently running Rasbian Stretch with Evok (https://github.com/UniPiTechnology/evok#testing-latest-git-versions)
      Evok lists 1wire as empty but this might be because i have not configured it properly:
      #!! don't use # for inline comments
      [MAIN]
      log_level = ERROR   ; one of INFO, DEBUG, WARNING, ERROR, CRITICAL
      log_file = /var/log/evok.log
      webname = unipi-neuron
      staticfiles = /var/www/evok
      ;password =
      ;rpcpassword =
      secret =
      port = 80
      enable_cors = False
      cors_domains = *
      modbus_port = 0
      #modbus_address = 127.0.0.1
      modbus_address = *
      [NEURON_1]
      scan_frequency = 2
      scan_enabled = True
      [OWBUS_1]
      owbus = --i2c=/dev/i2c-1:ALL     ; scanned bus (--i2c=/dev/i2c-1:ALL or localhost:2122 or 'u' for USB dongle)
      interval = 3          ; [s] default sensor reading
      scan_interval = 300    ; [s] how often is made searching
      How did you, friendly forum member, get 1wire to work?
      • S
        Solved the problem, I did two things wrong:
        • I had enabled the 1wire-interface through raspi-config, turning this off made the sensor show up in evok
        • I had two bad sensors connected to the hub
        Evok output:
        1Wire Sensors/Devices
        Sensor DS18B20 - 28FF896672150104:   19.1°C
        Sensor DS18B20 - 28FF1FDF7215012D:   20.1°C
        Sensor DS18B20 - 28FF71B761150300:   39.5°C
        Sensor DS18B20 - 28FF147F611502B8:   37.9°C
        Sensor DS18B20 - 28FFFEA162150371:   20.6°C
        Sensor DS18B20 - 28FF55B66215038C:   45.6°C
