    Evok, json, Python2.7, read multiple inputs so SLOW??
    1
      capitanfindus last edited by capitanfindus
      Hello, here I post my code. "s" is the server instance from jsonrpclib.
      while 1:
      i1=s.input_get_value(1);
      i2=s.input_get_value(2);
      i3=s.input_get_value(3);
      If I only read one input, response time is approx 0.1[s]. But if I read all 12 (not DI13 and DI14) inputs (also with for loop writing into array) it takes 0.7 to 0.8 [s].
      Any idea on how to speed this up? I can't have that latency when reading all inputs. My idea is to have a while 1 loop to have coherent info inside it: read input, do my code, set output.
      Thank you for help!
      Is there anything like this?
      https://github.com/kimmoli/evok/commit/14442a67cd79b211c2c8756092a4aa0314f1f741
      ps: UniPi 1.1 (full version wiith 8 output relays)
      ps2: VERY IMPORTANT: in the webbrowser the status of the digital inputs has no delay! I found with measuring timers that is the "s.input_get_value(1)" operation that takes a lot of time. Any other way? Using PIGPIO is ok to read digital inputs?
        Websocket solved the issue. Thank you
